Reversing a HHG Joint http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=8228 |
Author: | SStallings [ Wed Aug 30, 2006 1:15 pm ] |
Post subject: | |
I glued up a back with HHG and have a small gap at the bottom of the joint which is going to cause problems. How do I get the joint unglued? Thought about using a damp wash cloth and an iron to create the steam to loosen the joint. Any other or easier solutions? |
Author: | Alain Lambert [ Wed Aug 30, 2006 2:02 pm ] |
Post subject: | |
Just saw (rip) in the joint. |
Author: | Kelby [ Wed Aug 30, 2006 2:49 pm ] |
Post subject: | |
A heat gun works well. |
Author: | crazymanmichael [ Wed Aug 30, 2006 9:25 pm ] |
Post subject: | |
with hide glue you want moisture as well as heat. if the plate is still rectangular and you have enough room, it is easiest to just rip it. if you have cut it to the rough shape moisture and heat will separate it. |
Author: | Serge Poirier [ Wed Aug 30, 2006 10:32 pm ] |
Post subject: | |
An exacto knife heated on the hot pipe and a heat blanket to heat up the joint ! |
